Fuel Injectors
Old Jan 28, 2008 | 08:10 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Fuel Injectors
Hey guys, can someone help me out here and tell me if these fuel injectors from Summit will fit my '88 IROC-Z 305 TPI? They are Ford 19lb injectors. Thanks.
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 29, 2008 | 02:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Fuel Injectors
Yes, the Ford SVO injectors will fit in our TPI systems.
Old Jan 29, 2008 | 10:27 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Fuel Injectors
But if you plan on doing any motor work like a cam, intake, maybe jump up to 22# or 24#.
Old Jan 29, 2008 | 12:02 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Fuel Injectors
Yes, they will fit, make sure to use the clips that locate the top of the injector into the fuel rail. Also, these are the EV1 stlye injectors, so they will have the correct connector for you.
While you are at this, I would install an AFPR and a good fuel pressure gauge for tuning purposes. Measure the fuel pressure now before you take anything off the engine, this fuel pressure will be a good starting point for you after you install your new fuel injectors.
Old Jan 29, 2008 | 02:38 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: Fuel Injectors
I just put an AFPR in about 2 months ago. I just wanted to make sure these fit the car. I'm not really going to get into any motor work with this engine. I'm only 17 and don't have money for that kind of stuff. Someone told me that my injectors could be the cause of my car having a poor/erratic idle. I've replaced and adjusted the TPS and IAC and MAF. But thank you for all the responses.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
