New Headers Hitting Oil Pressure Switch
Old Jul 12, 2001 | 09:30 PM
S10Wildside's Avatar
I just got a set of Sanderson headers for my L98. The engine is in my S-10 so that's what the headers were made for. The oil pressure switch (or is it the sending unit??) right above the oil filter sticks out of the block too far and hits the collector on the header. How can I get around this problem?
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old Jul 12, 2001 | 09:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm thinking you could relocate it to the rear of the intake manifold on the block(towards the driverside), should be a 1/8th NPI plug there on the block.
Old Jul 12, 2001 | 09:42 PM
Thanks, I'll take a look at that tomorrow. The trouble is I don't have much room between the back of the block and the cab (which isn't on the frame at the moment). I wasn't sure if I could get some type of elbow to point the sensor forward instead of outward.
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, Sanderson Ceramic Coated Headers 1993 Typhoon Drivetrain
Old Jul 12, 2001 | 09:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't know how close you currently are, or in what relation the sensor sits and hit the header, but common elbows are 90* and 45*.
I've use 45* elbows off the rear of the block, to a 2 or 3 inch long piece of 1/8th inch pipe (NP) to the oil sensor in order to clear some room for close firewall fits.
In my '57 w/BBC, I'm so close to the firewall, I can't run a large cap HEI, but used the 45 elbow and pipe to clear the firewall.
There's also some specialized fittings for 90* and tight clearances, you'd have to go to a good supply store most likely.
Old Jul 12, 2001 | 10:07 PM
That's what I needed to know...thanks for the info!
1982 S-10 Wildside
Old Jul 13, 2001 | 09:06 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
We just finished replacing an engine in an S10, and the stock location for the oil pressure switch is right where 8Mike9 describes.
It is mounted on a 90* elbow and points to the passenger side of the truck. It is not a stock elbow, so you may want to go to a boneyard and get one, or pick one up from a GM dealer...
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors,
custom chip, Walbro hi-flow fuel pump, Accell HEI billet distributor.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
