Smog Pump
Old Jul 13, 2001 | 01:51 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Smog Pump
I've read the articles and posts about removing the smog pump and decided I want to... a friend will be helping me do it on sunday... I don't expect noticable power gains, but i do want the extra space freed up, less weight on the car, and not have to worry about getting headers and a new cat w/ air fittings.
I've recently heard an argument that the extra o2 that the pump gives to the cat and headers helps stop carbon buildup... any truth to that? I plan on changing the cat within a month to a hi-flow and the headers within the year. Is there any detrimental effect I should expect?
I want to do this, and most likely will on Sunday. just tryin' to get a final survey in. thanks in advance for your opinions.
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS, The F-Bod Squad, 3 guys so far and I don't think we're growing
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
AOL IM Name: JimmyTime5
Old Jul 13, 2001 | 02:15 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
No it should be fine. I removed my smog equipment and left the factory manifolds and dual cats on for about 6 months before I got headers and high flow cat. You shouldn't have any problems just make sure you keep the holes in the manifolds plugged up.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Jul 13, 2001 | 05:04 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Thanks Steve . Went out and bought the plugs at Depo after I posted, so looks like I'm set
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
