Dang Dog!!!
Old Jul 13, 2001 | 12:34 AM
rockind78's Avatar
Dang Dog!!!
Well, its been like 3 weeks now and I still can't believe it. One of my dogs chewed off and mangled an injector boot off my '85 T/A harness while I had it out doing some work to it. I left to get a bite, came back and it was missing. Anybody know if there is any kind of an aftermarket for something like this? V8 TPI harnesses are VERY scarce in my area. Perhaps an injector boot from a different kind of car might work??? Any help would be greatly appreciated. Thanks guys!
Old Jul 13, 2001 | 08:23 AM
leirch's Avatar
Go to a junk yard and start looking for a MPFI GM car. I'm sure they are all the same but just go and take a look, get alot of the harness before the injector boot and you should be ok.
Oh and I would have beat the dog
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 13, 2001 | 09:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think you will be ok, 3800 MPFI Engines should be the same.
John
BEATING the dog is ILLEGAL, But taking it to the Vet to put it to sleep is not, go fig.
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jul 13, 2001 | 12:37 PM
irocbsa's Avatar
Tell that to all the rednecks around here. They beat the **** outta those things.
bsa
Old Jul 13, 2001 | 01:21 PM
long&low
Guest
Posts: n/a
Hell I have eight brand new boots,connectors,and pins.how many do you want?
Old Jul 13, 2001 | 05:08 PM
rockind78's Avatar
Thanks for all your input guys! On a chance, I went to a local junkyard around here (the only one) and the guy at the counter happened to KNOW that V6 Celebritys, Centurys and Pontiac 6000's (the MPFI's of course) all have the same boots and stuff. Snip, snip...One Century minus one injector boot and I am a happy camper! The dog wasn't in my good graces to say the least!
NORTz89
May 20, 2020 03:51 PM
cheesehomer
Dec 31, 2015 08:48 AM
3rdgenkindagal
Sep 29, 2015 01:41 AM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
mult68
Sep 27, 2000 01:05 AM
