taking off the intake manifold and heads
Old Jul 13, 2001 | 08:48 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i can get the heads with no prob i think but what do i need to watch out for when taking off the intake manifold?
i'm going to port the intake manifold and gasketmatch/mildly port the heads.
what do i need to watch out for with the distributor? is there a tech article that explains this in detail?
thanks for all the help
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Hooker Competition Ceramic Coated Headers, Flowmaster, Ported Plenum
All smog equipment gone and no cat
before headers
192hp and 265tq
15.20 @ 92.5 mph 2.4 60ft
After Headers
14.480 @ 95.01mph 2.194 60ft
Old Jul 13, 2001 | 11:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
start by unboltiing the runners top and bottom if you have the tb bypass the plenum will slide off(disconnect the throttle/downshift/cruise cables and vaccum to the fpr)if not disconnect that as well(coolant will spill)loosen the fuel rail bolts 10mm socket pop the rails out of the bores enough to slide out the runners from underneath them to save you the hassle of depressurizing the fuel system leave the lines connected to the rails lay a towel on the drivers sidesttrutt tower and flip it over and upsiide down aand laay it there with that removed disconnect your sensors from the intake loosen the intake bolts t35 torx bit take off the distributor cap mark the rotor posistion loosen the hold down bolt ttwist and pull out the distributor the intake miight need some coaxing gently lift it up with a small flat tip you will have to take the manifolds or headers off to get to the head bolts watch the ground wires on the back of the drivers side head as well as the air injection tube on the pass side dont yank anything look carefully and you will see everything.....good luck!!!!
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
ed wright's fastchip saturday!!!!slp catback is finally on!!!
FLOWMASTER S.U.C.K.S
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
