Code 34 on my MAF
Old Jul 14, 2001 | 06:08 PM
JucinGTA's Avatar
Code 34 on my MAF
How do I go about gettin that to go away?
Old Jul 14, 2001 | 10:45 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Dont know if it will fix it but try replacing the 2 sensors for the MAF the burnoff and power(?) now that I type this I cannot remember the name of the other sensor hopefully someone will come to my rescue.
Old Jul 15, 2001 | 01:20 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Hey Tony, replace your MAF relays. Beacon Auto carries them for like $7 a piece i think. If that doesnt work, well then your in the same boat as me
Old Jul 15, 2001 | 10:29 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Check all your connections for corrosion. Clean the pins and sockets of your MAF connector with a jeweler's file and/or alcohol. Usually though, like what was mentioned before, a Code 34 means bad burnoff or power relays. They are located on the driver's side of the firewall, flanking the fuel pump relay.
Also, check your TPS voltage, make sure it's .54v+/-.075v. (The procedures are outlined in the tech articles section). Good luck and let us know if it works.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
[This message has been edited by Kevin Irving (edited July 15, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
