TPI on an older 320 block?
Old Jul 16, 2001 | 04:02 AM
IH8FORD's Avatar
I was wondering what year of block I would need to run my TPI setup on? What I want to do is, build another bottom half while I still use the engine in my car. Then when I am finished switch them out. Is their anything I need to know when searching for a block? I know the heads are kinda diffrent on TPI setup so what am I looking for? Any Information will help greatly. Thanks again
88 Firebird Formula
350 T.P.I. (Stock unfortunately)
Old Jul 16, 2001 | 04:04 AM
IH8FORD's Avatar
Sorry guys it is suppose to say 350 outside common typo.
Old Jul 16, 2001 | 10:13 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There is nothing special at all about the engine under a TPI. In 87 the center intake bolt angle changed, thats the only difference. If you plan to use your stock base then you will have to modiy the 4 center bolt holes if you want to bolt it to early style heads. Aftermarket bases don't have this problem, they take both intake bolt angles.
...ed
Old Jul 16, 2001 | 09:50 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
in addition to ed's comments 87 and later came with provisions for a roller cam spider tray.if your intent is to make the most of the quick ramp speeds of a roller cam look for an 87 or later to save the hasssle of special lifters and a cam button.a 2bolt will normally not even bat an eye at 400hp decide on whatt you want then search for the candidate for your mods
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(she's on a diet,get me down tto 3200 like a ford and it'll lift off.
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
