Dented TPI runners? No prob.
Old Feb 2, 2008 | 04:35 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I just wanted to share a method of removing dents from tpi runners. This works great and also works for other dented items such as exhaust pipe or headers ect.
Its simple.
Fill them with water
set them so the water is pooled in the dented area.
stick them in the freezer.
The dents will pop out a little more each time.
you might have to repeat 2 or 3 times.
I have used this method on several other parts and it works great, so far i have never split or damaged anything by doing this.
If you have dented runners give it a try you will see.
Thanks,
Jeff
Old Feb 2, 2008 | 05:01 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Re: Dented TPI runners? No prob.
For TPI runners I like the steel ball that I saw people selling. It is the same size as the ID of the runners so force them in and it fixes the dent. I have never tryed it.
Old Feb 2, 2008 | 05:35 PM
Damon's Avatar
The power of freezing water is incredible, isn't it?
That's really invetive! Never would have thought of trying that.
Old Feb 2, 2008 | 05:49 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
It really is! And free too.
Old Feb 2, 2008 | 05:55 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
One thing I can say about the "ball" method is that if you have a pretty bad dent and when you force them through it create "ribs" on the runners due to the pressure of them pushing against the runners while trying to force them through. I actually thought of trying to use water and freezing them first, but I had a guy on another site offer to use the ball method for a good price.
Old Feb 2, 2008 | 06:05 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
When you say "pool", what exactly do you mean by this? correct me if I am wrong, but if you fill the runner completely with water then how is is supposed to pool anywhere, due to the fact that the water is now completely filling the volume of the runner 100%. I need more information my friend. I have a few extra runners I could try this on, so This may kick a$$ if done correctly.
Cheers!!
Old Feb 2, 2008 | 08:52 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Basically, you want the runners tilted, so the the dented area is completely filled with water,(inside the runner....) then, when it expands as it freezes..... isn't water wonderful.... it will pull a little of the dent. to repeat the process, just allow the water to thaw, maybe add a little more, and freeze it again. Time consuming, but, eminently practical.
Old Feb 2, 2008 | 09:59 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Yep, hes correct. I dont ever plug both ends just one, then set it so the water doesnt run out. This way it wont split the runner or tube. I use this method on my dirtbike exhaust's too. Works great. I pulled a golf ball sized dent out in 2 freezes. you could literaly take a crushed runner and get it back into shape by freezing it enough times.
Old Feb 3, 2008 | 06:51 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It's more in the positioning of the runner in the freezer once it is filled with water. Very similar to when you leave a can of sealed soda can(s) in the freezer for too long, see pic....
Old Feb 4, 2008 | 11:08 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I understand the expansion when going from water to ice.
But I'm not understanding how you contain it to the damaged area? I am thinking that it would expand to the least resistant area.
Could someone draw a diagram for me.
Old Feb 4, 2008 | 01:58 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
The dented material has "somewhere to go" It applies pressure to the whole tube, but the the rest of the tube is in its normal shape so the water just elongates in the tube, meanwhile the pressure applied to the dent removes it.
Old Feb 4, 2008 | 03:01 PM
Dale's Avatar
Engine: 350 S-TPI
But as it gets larger/freezes. Wont it expand into the area of least resistance? This being the open ended runner?
Old Feb 4, 2008 | 03:24 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
yes, but not completely. as the water freezes it will want to apply pressure in all directions, which is why it can possibly take multiple freezes.
Old Feb 4, 2008 | 03:31 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Yea, thats correct. You can cap both the ends off, but thats risky and I don't advise. The force of freezing water if contained is enough to split solid steel. Chances are it would push the caps out, but i dont advise trying both. Just cap one end.
Old Feb 4, 2008 | 04:15 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
So, how do you prevent the water from running out?
Old Feb 4, 2008 | 04:41 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey 92rs85berlinetta, I can see how your method works on TPI runners -
but how do you get a pair of Hooker 2055's ( or one header for that matter )
or a dented Y-pipe full of water into a freezer ?
" The secret of life is honesty and fair dealing...
If you can fake that,you've got it made. "
Groucho Marx
Old Feb 4, 2008 | 04:49 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
It was a typo. I meant to say plug one end NOT both. Then just position it so the other end faces upright.
My parents have a chest freezer at their house. I just toss it in there. Just fill the dented primary and freeze. Or if you live in the north, just leave it outside lol.
I get creative when plugging ends. I have used everything from bbq sauce caps to screw on Gatorade bottle tops. I like exhaust plugs for atv's and dirt bikes best, they are tapered so you can really jam them in.
Dale's Avatar
Engine: 350 S-TPI
Then how does an icecube tray not split?
Old Feb 4, 2008 | 04:51 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Its not contained and its flexible.
Old Feb 4, 2008 | 08:05 PM
Dale's Avatar
Engine: 350 S-TPI
exactly on the contained part. If I only have 3 sides of the runner filled, then it will expand into the area not contained.
Id love to do this as my runner has a large dent. But I'm just not seeing how this is done.
Old Feb 4, 2008 | 09:06 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
exactly, It has to exert pressure in all directions in order to go to the least resistance. Water will expand putting pressure on the dent and push it out. Give it a try, you will be impressed. might take 2 or 3 times. The most i have ever done it was 3 times.
Old Feb 4, 2008 | 09:24 PM
ploegi's Avatar
Engine: 5.7 TPI
Also, an icecube tray has tapered sides, not square. So, as the water expands, the entire cube is forced up further in the tray. You will not see any icecube tray that is not curved on at least one surface.
Don't think this works? Need some Proof? Take a glass of water, throw it in the freezer. Wait till you here the "POP" of breaking glass. Open freezer, notice how the glass is now blown into chunks. Hhhhmmmmm....... It has an open top alright, but the expanding water still blows it apart.
Old Feb 4, 2008 | 09:42 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Hell, if my 'Maro weren't my daily driver, I'd do this now.
Old Feb 5, 2008 | 06:51 AM
Dale's Avatar
Engine: 350 S-TPI
Actually, after I got offline last night. I took an empty coke can. Put some dents in different spots, filled with water and sat it in the freezer. None of the dents this am seemed to be smaller. The water did expand up as I filled it to the bottom of the lid thing that hangs down in the can. This morning it was almost to the top of the opening.
Old Feb 5, 2008 | 09:58 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
If you dont believe it, try it on a runner. It works, I have done it to many different things and its worked every time.
Old Feb 11, 2008 | 12:14 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Hey guys heres some pics I dug up of this procedure. Before and after. Its not a runner, but a titanium pipe. you get the idea, check it out.
This is not my pipe, but I have another Titanium pipe I did this too as well.
Old Mar 5, 2008 | 08:36 PM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
I've tried this method about 15 time and can get it to phase any dents. Little or big. Any tips? I have just been duct taping the holes closed on one side and it holds the water in untill it freezes. I fill them completely up. I havent noticed any difference in 15 tries. Whats goin on. Has onlyone used this on their runners?
Old Mar 5, 2008 | 09:19 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
how long are u letting it freeze for? is the water pushing out both ends? try capping it off better with something a little harder than duct tape.
Old Mar 6, 2008 | 06:03 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
How cold is the freezer? some are at 20 F, chest type 0 f. Easy way to tell. Is the ice cream, really hard, hard, or kinda soft.
Old Mar 6, 2008 | 08:49 AM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Im living in Michigan during the winter so i've used the freezer but I usually just fill it up and set it out the back door.
Old Mar 6, 2008 | 09:13 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
and it is how cold outside when you do this?
Old Mar 6, 2008 | 09:44 AM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
10-20
Old Mar 11, 2008 | 09:55 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Still having problems. I have froze them about 15 times or more and still cant get a bunch of little dents out. I trust the theory but i cant figure out why it wont work for me. I've plugged one end with a rubber expansion plug and put them in a chest freezer cranked all the way up. I can tell the ice is comming out the other end but the dents are still there. WTF?
Old Mar 11, 2008 | 10:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This method works on dented motorcycle fuel tanks too.
Old Mar 11, 2008 | 11:26 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Damn, I have a full length side pipe header off an old T/A Id like to try this on but its huge and I dont have a freezer big enough. Why did'nt you post this a month ago when it was really cold here?
Old Mar 12, 2008 | 01:21 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
sweet I got one question how do so many people have dented runners.....what are you guys doing thats denting them?
Old Mar 12, 2008 | 07:07 AM
Dale's Avatar
Engine: 350 S-TPI
The intake set I bought had dents in them, so it wasnt me.
I still havent taken mine off as I'm worried about other things on the car first.
Old Mar 12, 2008 | 02:15 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Are they tiny dents? I noticed the tiny crinkle dents dont like to come out as easy. Maybee try plugging both ends.. at your own risk of course.
Old Nov 5, 2011 | 08:51 PM
theremikegoes's Avatar
I know this is an old thread but I had trouble with freezing method not working until I figured another trick out, got a few pretty large/sharper dents out...
freeze the runner with water
heat dent with a torch to melt the water at the dent (dont melt all of it)
refill as needed
refreeze
repeat
This way you get more force directly on the dent when you re-freeze. I tried freezing and melting fully several times before I figured this way out.
Old Nov 5, 2011 | 09:00 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Have pictures? This old thread is interesting.
Old Nov 5, 2011 | 09:29 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Old time pioneers used to break granite blocks for buildings this way - drill holes in the rock - fill with water - come back a day later. Great idea.
Old Nov 5, 2011 | 09:35 PM
  #42
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
refill as needed
refreeze
repeat
Thats a good idea to isolate the dent, that makes the pressure of the expanding ice push only on the dent itself since the other ice wont let it expand anywhere else. It take a few freezes but it works good. The trick is to block the ends so that the water pushes on the dents and not out the ends. If it just pushes out both ends its pointless.
Thats a new term Iceolation ok... bad joke.
Old Nov 6, 2011 | 11:46 AM
  #43
Zipacna's Avatar
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
I have had success with this as well. Warm water will actually freeze fast than cold but its true.
I plug one end usually by bolting something over it with a stopper. Fill it with warm water. And then put it in a towel so the metal of the runner isn't touching anything. The open end should start to freeze first and hydraulic pressure is constant.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
