Fuel pressure drops when relay goes off..
Old Nov 2, 2011 | 11:50 PM
rockstar08's Avatar
Car: IROC-Z
I am trying to troubleshoot a hard start condition. When i turn my ignition on after a 10 sec wait, the fuel pressure on the rails goes up to 42psi, but quickly drops to zero after the relay clicks off.
When I pinch off the lower fuel hose, ( the return i think? ) pressure goes up to 60psi and holds.
The service manual recommended replacing the FPR, I have already replaced the FPR diaphragm, there is no external fuel leaking around the rails or fpr.
Any ideas?
Old Nov 3, 2011 | 12:27 AM
rockstar08's Avatar
Car: IROC-Z
Re: Fuel pressure drops when relay goes off..
Just retested for my own sanity, fuel pressure also holds when I pinch off the top hose ( fuel pressure line? ) does this mean that my fpr is ok and the problem lies in my sender unit/pump?
Old Nov 3, 2011 | 02:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Faulty check valve on the pump maybe?
Old Nov 3, 2011 | 06:31 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Your fuel injector nozzles are leaking fuel down into the cylinders. Very common problem. The bleed down to zero on pressure right away is the classic sign. You need a new set of injectors.
Old Nov 3, 2011 | 07:32 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As per post # 2.
If injectors were leaking pressure would not hold
Part of the test ;
if pressure drops with both lines clamped then only place leak can be has to be the injectors
Old Nov 3, 2011 | 08:31 PM
southbay08's Avatar
Old Nov 3, 2011 | 09:51 PM
rockstar08's Avatar
Car: IROC-Z
I replaced the pump and sender unit today, checked for leaks on all fuel line fittings ok, now when i pinch off the return hose I get 90psi, that holds. When i pinch off the pressure hose it drains down??
As it holds 90psi when I pinch off the return am I right in thinking that the injectors are ok, and the only place it could be loosing pressure is through the return of the FPR?
Maybe the fpr valve seat is worn..
The FPR holds 35psi at idle and 42 when the vacuum is disconnected, that leads me to believe its doing its job?
Any ideas greatly appreciated..
Old Nov 3, 2011 | 11:29 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
my pressure drops to 0 within 5 minutes of turning the motor off and will start up in 2~3 crankshaft revolutions, even if it has sat for a week or 2.
as long as the fuel pressure comes up right away to the same pressure as with the vacuum hose off the regulator with the motor running, when you turn the key on it shouldn't cause a hard start.
problems with the cold start valve are pretty common, is the hard start only when cold? or is it all the time?
Old Nov 3, 2011 | 11:37 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What does it do with both lines clamped?
Old Nov 3, 2011 | 11:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I have a Aeromotive reg on my 383 that holds no pressure whatever and fires ups straight away
Old Nov 4, 2011 | 12:08 AM
rockstar08's Avatar
Car: IROC-Z
With both hoses clamped ( the pressure hose after the pump has run ) it holds 90psi. I don't have a cold start valve on my year.
I'm thinking the base of the Pressure regulator where the base of the diaphragm seats is leaking.
Interesting that you guys don't hold any pressure but start right away. It does go straight up to 42psi, may be the problem is elsewhere then..
Plugs, cap rotor, coil, injectors, battery, charging system, timing, fuel pump, sender have all been checked..
The EGR valve looks kinda rusty, but can this cause a hard start when cold?
Old Nov 4, 2011 | 07:24 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Little test.
Jumper the wires in the FP relay so pump runs full time ( maintaining rail pressure )
and do a start.
If hard start still exists ,then not fuel pressure related.
If instant start then pressure drop is your start problem
Old Nov 4, 2011 | 03:22 PM
rockstar08's Avatar
Car: IROC-Z
Thanks vetteoz, that's a great suggestion, I added 12v to the red fuel pump prime wire behind the passenger side strut mount, this spun the fuel pump continuously. Still had a hard time starting, fired on second turn of the key,
So I am thinking it not fuel pressure related.
Possibly an ignition problem?
Old Nov 4, 2011 | 06:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
How good are your injectors?
Old Nov 6, 2011 | 02:20 PM
rockstar08's Avatar
Car: IROC-Z
They all ohm out to be the same resistance, so I am guessing they are good, I can hear them clicking on and off okay through a steth. They are reconditioned ones, about 2 yrs old.
I spraked carb cleaner around the bases to see if theyre drawing in any air, they appear to be good.
The weather had cooled down alot here in AZ, the car starts first time now, although it does take 2-3 secs to fire up.
MAP sensor?
Bryan F
Aug 18, 2015 02:28 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
