Excess Carbon Build-Up?
Old Jul 18, 2001 | 06:51 AM
Mrfixit's Avatar
I started taking my TPI apart to do some detail work and was amazed at the amout of carbon build-up I found inside the upper plenum and tubes. The motor has 74,000 miles on it and has had the smog pump disabled for quite some time but the EGR is still there and working. Is this kind of build-up normal?
Roy
Old Jul 18, 2001 | 12:06 PM
IROC-Z_85's Avatar
When I ported my plenum i had plenty of carbon as well, I dont think its any kind of problem, but you'll need to get all the metal shavings from the porting out so I just used carb/brake cleaner and it took the carbon with it.
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
Old Jul 18, 2001 | 12:35 PM
IROC-Z_85's Avatar
That carbon is probably from your egr/pcv valves.
1985 IROC-Z
grngryoutmyway
Oct 18, 2016 05:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
89bird2.8
Sep 18, 2015 07:46 PM
