Where you guys putting your Ignition Boxes?
Old Jul 16, 2001 | 07:56 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
I cant find any space where I can put it. Any ideas or pics would be great thanks.
Old Jul 16, 2001 | 08:31 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I've seen most mounted on the strut tower hump. Mine is on the firewall, driver side. After my ZZ4TPI swap I had room when I ditched the 305 TBI relays.
Some also move the charcoal canister and mount it in that spot.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jul 16, 2001 | 08:53 PM
IROC5.7TPI's Avatar
I too have been looking for a good spot. I was considering making a plate for it that mounts on top of the battery. Another place is where the washer fluid bottle is located. I was going to go boneyard hunting for a smaller one and mount it elsewhere. Another place (for us IROC owners) is under the airbox area between the headlights, like on top of the impact beam.
Any opinions on any of these?
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jul 17, 2001 | 06:30 AM
Kyle F's Avatar
I removed my AC and mounted it on the flat blowe housing, if this is not an option for you I know a lot of people relocated their Canister and put it out front.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jul 17, 2001 | 07:45 AM
Buck Mustard's Avatar
My MSD box is mounted on a plate over my battery... and I hate it! It makes it really difficult to get to the battery.
I am currently scoping out moving it to the other side of the car where the charcoal canister used to be.
Doesn't make much sense to put it anywhere where it is going to interfere with your accessibility to another component. Also, I have heard that you don't want to get it too close to headers due to heat.
'88 GTA w/ t-tops
355 TPI, TPIS airfoil, Edelbrock headers,
Flowmaster exhaust, cold air induction,
MSD 6AL ignition, ADS chip, 1.6 rockers on intake,
BMR STB, Spohn SFCs
Stereo:
Panasonic CQ-DFX700U
Infinity 4x6, Alpine 6x9
Rockford-Fosgate Punch 400a4
80 watt Bazooka sub
Old Jul 17, 2001 | 09:19 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I relocated the firewall relays on the driver's side to the fender. The wires still reached so no harness splicing. Then I mounted my MSD to the firewall. It was a total PITA because I used the rubber isolator feet and had to cram my hands in through the cowl opening to put nuts on the ends.
If I did it again I'd mount my MSD in the passenger compartment up near the ECM. Matter-of-fact, I'm probably going to relocate mine there fairly soon.
Old Jul 17, 2001 | 11:00 AM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by afgun:
</font>
Don't get it too close to the ECM. It might interfere and throw codes.
Just a thought.
Old Jul 17, 2001 | 11:45 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
If you look below the power brake booster there is a rubber gromet in the firewall plugging a hole that is big enough to pass all the wiring for most ign. boxes.
I just fed the harness through this and sealed it and mounted my box to the bottom of the dash.
unless you really want to SEE your box, I think this is the way to go since it offers the most protection for the electronics.
Old Jul 17, 2001 | 04:59 PM
irocbsa's Avatar
I mounted mine in the passenger compartment. I put it down on the panel right in front otf the door tot he right of where the passenger's feet go. I probably need to move it. I always have to tell people to watch their feet.
bsa
Old Jul 17, 2001 | 08:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I installed mine on the passenger side strut tower. On the back side of it towards the fender. I used some 3M tape to stick it to the tower. There is just enough room there for it. Its close to the coil and battery so it was easy to hook up.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jul 18, 2001 | 10:41 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
I mounted mine inside hanging from the bottom of the air conditioning box. Plenty of room.
Mark
Old Jul 18, 2001 | 01:26 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I remounted my canister over about 3" invard, and mounted my 6a there. I don't think that this will work with the 6al though, sience it is wider. I know a guy with the 6al who ended up mounting it under the hood latch area. I took a pic of my setup and will post it up later on tonight, pending photopoint is back up! If not, anyone know of any good free image hosts?
Old Jul 18, 2001 | 03:40 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
Thanks for the replies guy's. I decide to put mine behind the brake booster it just fits there nice and snug.
Old Jul 18, 2001 | 08:42 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Here you go! I moved over the box about an inch or two and drilled new holes to mount up the canister. HTH!
Old Jul 18, 2001 | 08:45 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Ugghh... photopoint is really starting to suck now that they have changed hands. Not only do they want money to use it, but no more hot linking into a forum. Yuck. Here's the page link!
http://albums.photopoint.com/j/View?u=1695518&a=13019809&p=50975884&Sequence=0&res=high
Scrach that. No links period. Kinda reminds me of crappy geocities. Geez I guess it is back to e-mailing! Anyone need it email me at eds11979@hotmail.com .
[This message has been edited by ES87iroc (edited July 18, 2001).]
BRoss99
Aug 10, 2025 05:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
