Which AFR heads should I get??
Old Jul 18, 2001 | 12:06 PM
CamaroX84's Avatar
I need a head recommendation for my setup. Mods are in sig. I plan on adding a SuperRam with the Edelbrock base at the same time as the heads. I really want AFR heads. Probably the 190cc heads. But, within the 190cc heads, there are so many different variations. ANY help would be greatly appreciated. If you have part numbers, that would be great too. Thanks in advance.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Old Jul 18, 2001 | 12:17 PM
IROC-Z_85's Avatar
Go miniram
[This message has been edited by IROC-Z_85 (edited July 18, 2001).]
Old Jul 18, 2001 | 02:21 PM
SillyWabbit's Avatar
Car: '91 Formula
It depends on what you want, and the engine you have. The SBC Street Heads come with either straight, angled, or L98 angled plugs, depending on which block you have. Other than that, you need to determine whether or not you want or need SMOG legality. I think the specs are the same, other than the 68 or 70cc combustion chamber sizes.
Old Jul 18, 2001 | 03:34 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The plug angle doesn't matter for your block. It matters for your exhaust.
The chamber size matters for the compression ratio you are looking for. You'll need your piston specs to calculate.
Me, I ordered 190cc heads with the 74cc chamber (AFR said the 74cc chamber design is slightly more efficent than the 68cc chamber) milled to 68cc. The plugs are on the L98 angle.
For a street motor you'll want to get the temperature sender holes drilled and tapped for sure, and if you want to run EGR and/or a carb preheat (or to be emissions legal!) you'll need to order the heat riser version.
The 190 head is supposed to match up pretty well with the super ram base. I'll let you know when my heads arrive
Old Jul 18, 2001 | 08:46 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i heard the tfs 23* heads flowvery well are an out of the box bolt on tthe only thing afr's are cnc finished for a smoother port
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 18, 2001 | 09:11 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Get the TFS 23* and get them ported, then they will flow better than the AFR's and will come out cheaper.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
