TPI 3000-4500 RPM misfire
Old Feb 4, 2008 | 07:59 PM
z28_guy_377's Avatar
Can anyone help me out? i have a 84 Z28 that i installed a stock 305 and TPI with MAF off of an 87 IROC. I have replaced everthing in my ignition system and still i have a missfire around 3000-4500 RPM. The engine runs well till then ,, but as soon as i hit around 3000 RPM the tach starts jumping around and the engine surges and backfires throught the exhaust. When i unplug the timing conector from the computer it seems to run better. Does anyone have any sugestions? THANKS!!!!
Old Feb 5, 2008 | 08:38 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: TPI 3000-4500 RPM misfire
* check your timing, should be 6deg with timing connector (EST) disconnected.
* check your dizzy/ignition module
Old Feb 5, 2008 | 06:55 PM
Thanks for the reply!!!!!!! i found my problem... distributor gear was shot...I put a new one on the shaft,, it runs smooth!!!!!!!! THANKS!!!!!
Old Feb 5, 2008 | 07:08 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
CONGRATS!!
Glad to hear your in good shape now.
BTW, welcome to TGO! I absolutely LOVE this place.
mdtoren
Aug 23, 2015 12:52 PM
jbd1969
Aug 17, 2015 07:06 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
