Will I notice a difference using 1.6 rockers?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
My cam is 206/210 duration. 450/480 lift and 112 degree seperation. 1.6 would give me a 480/512 lift. would i notice this?
[QUOTE]Originally posted by EDGE:
My cam is 206/210 duration. 450/480 lift and 112 degree seperation. 1.6 would give me a 480/512 lift. would i notice this?[/QUOTe
I put them on my car I went with roller rockers as well.It seemed to improve it a little. but sometimes I think it's more in my head then any thing.To be honest it seems the more people are going by way of (8)1.5
(8)1.6 which is what I wanted to do but I could find a set of self aligning narrowbody centerbolt split like that.And I was about to buy sets of each at $300 buck a set.If your firmalary with TRAXION on this site I believe he has 1.5-1.6.Maybe you could drop him a line and see how he went about 8 of each
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
<font face="Verdana, Arial" size="2">Originally posted by Matt383:
I'm going with a split set as well. Already have the 1.5s, going to order 1.6s end of week.
Matt</font>
Matt</font>
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good and it works)
I would assume it means putting 1.6 on intake 1.5 on exhaust, or the other way around. I guess it just depends on what kind of lift you want.
edit.. also, if your heads do not support lift over .510 or something, and the lift is already .460 .480, you could put the higher ratio on intake and be well below, while putting the higher ratio rockers on the exhaust would require head work. Just an example.
[This message has been edited by rezinn (edited July 18, 2001).]
<font face="Verdana, Arial" size="2">Originally posted by rezinn:
[This message has been edited by rezinn (edited July 18, 2001).]</font>
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
