help with gears
Old Jul 16, 2001 | 09:20 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
help with gears
if you look at my sig what do you guys reccomend for gearing i was looking at 3.70's but that might be to low and spin it past it's peak in 4th gear i know the tranny sn't gonna hold for long so if it's gonna break i wanna break it in three pieces(front shaft,rear shaft,and everything between......
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 16, 2001 | 09:21 PM
IROC-Z_85's Avatar
you dont want 3.73's and if you DO
buy mine
1985 IROC-Z, nuff said :P
Old Jul 16, 2001 | 09:32 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
3.70's are cheaper and a 9 bolt is better although they make a 3.70 and 3.73 for the 9 bolt if i was to choose blindly i'd go wiith 3.70's
Old Jul 16, 2001 | 09:34 PM
IROC-Z_85's Avatar
I went from the original 3.42's to 3.73's...
And i've felt like an idiot ever since.
Thats why it also bugs me that TPI doesn't rev
instead of changing gears, im almost considering going to a carb just to make up for the gearing.
Old Jul 16, 2001 | 09:46 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
why not get the extra rpm's from the tpi?i am gonna stiick to 9 bolt gears (3.27,3.45,3.70,3.73)thanx for all your input
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(she's on a diet,get me down tto 3200 like a ford and it'll lift off.
Old Jul 16, 2001 | 09:49 PM
IROC-Z_85's Avatar
I can't afford TPI rpms
Old Jul 17, 2001 | 09:59 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
<font face="Verdana, Arial" size="2">Originally posted by PETE:
3.70's are cheaper
</font>
I think you are backwards. Gears for the 9 bolt are meg bucks. 10 bolts you can get for next to nothing.
Old Jul 18, 2001 | 04:20 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
a whole set of gears att my cost was 265 not includng install kit for the 9 bolt and the 10 bolt was barely cheaper i mean penniies when it comes to the strength of the two
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
Old Jul 19, 2001 | 04:30 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
(see my rant - I mean post - on the other topic about gears)
Overall, the BW 9-bolt = slightly stronger but, waaayyy more $$$$$$ (try finding shims for it.... $$$bearings$$$ $$$carrier$$$).
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
