need help TPI dieties.
Old Jul 16, 2001 | 09:56 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
does anyone use the tremec trans in their f-body i'll be looking for a trans when i grenade this one and am thinking tremec tko/3.45 9bolt not to crazy a nice launch ratio and wont pull it out of my powerband.....all answers welcome
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete(she's on a diet,get me down tto 3200 like a ford and it'll lift off.
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 16, 2001 | 10:01 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
c'mon gurus looking for knowledge(the thirst of life)or at least a few opinions
Old Jul 17, 2001 | 07:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
They're a pretty good value, Pete, IMHO.
Do they make an 18 deg. canted trans. or does a 3rd gen have to go w/ a straight up one?
They have a 2.95 first gear version?
jmd
1986 SS with...
86LB9 TPI atop the original L69, hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
Old Jul 17, 2001 | 08:21 PM
Dan87IROC-Z's Avatar
Those Tremec TKO Transmissions are great. They should install in place of a T5 without any modifactaions nessassary. Yes, the TKO and the 3.45 gears should be perfect for your car.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 17, 2001 | 08:24 PM
By the way, PETE, did you have any trouble installing your SLP runners? I have heard some guys having trouble with the alternator bracket.
L98 TPI 350 (5.7L)
Old Jul 17, 2001 | 08:37 PM
Guest
Guest
Posts: n/a
The tremec isnt a direct replacement. Do a search, I believe you may find a post or two.
Old Jul 19, 2001 | 12:35 AM
whiterocz's Avatar
i was told my mike forte in an email that all i would need is a crossmember. the third gen's Tremec TKO uses a t-5 bellhousing.
Old Jul 19, 2001 | 07:22 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
even asked a few questions about the tranny and the stock crossmember canbe modifiedyou hhaveto lengthen the slots for the bolts to slide it back some cause thetremec trans mount is further back thanthe t-5.as for the slp's theyy fit great withthe exception of that stupid long bolton the bottom a real crappy idea i will be siamesing them completely soon...
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
