Resolved code 42 EST Problem.
Old Jul 23, 2001 | 10:28 AM
IROC5.7TPI's Avatar
After pulling out nearly every hair I had left on my head, I finally figured out why I was getting code 42 intermittently.
The blue connector going into the ECM houses a tan w/ white strip wire. Its the EST bypass that you disconnect to set initial timing.
The wire in the connector has given some play. After a wiggle check, I found this to be my problem.
Just a heads up before anyone goes replacing expensive parts. I refused to replace one single item until every area was checked. Glad I did
BTW-
Anyone know the "correct" way to fix that loose wire? I just gotta wiggle it into place and it stays there pretty good for a few weeks before coming loose again.
HELP
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jul 24, 2001 | 09:22 PM
whiterocz's Avatar
glad to hear yours was cheaper. my code 42 turned out to be a bad ecm (of course it was the last thing i replaced). oh well i got a new ignition module, coil, pickup coil, and ecm out of the ordeal. as for the connector, id just cut the old black connector off and go to autozone and get some of those quick-snap wire connectors and place inline with the wire.
Old Jul 25, 2001 | 10:04 AM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by whiterocz:
as for the connector, id just cut the old black connector off and go to autozone and get some of those quick-snap wire connectors and place inline with the wire.</font>
Its actually the pin out from the ecm. I believe the female inside the bulkhead connector is losing contact with the pin in the ecm. The actual pin looks fine. The female part in the connector is what seems to have some play, causing a intermediate open circuit.
Mike L.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
