Is it normal to smell fuel at the regulator?
Old Jul 26, 2001 | 10:55 PM
89REDGTA's Avatar
I pulled off the vacuum line at my fuel pressure regulator and it smelled like raw fuel. Is this normal? Should I replace the regulator? I'm fighting a rough idle problem and was wondering if this may contribute.
Old Jul 26, 2001 | 11:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You shouldn't have fuel on the vacuum line side, if you do, the it's being pulled through from the diaphram. Good time to replace it with an adjustable regulator.
Old Jul 26, 2001 | 11:31 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
YES you want to replace the rubber diaphram. If your getting raw fuel like that in the plenum that means the rubber diaphram is leaking and could lead to an EXPLOSION!! I have seen a 1999 Buick park ave.'s intake blown to peices. Although it was plastic, I would hate to see what it would do to a TPI unit.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire hope to get running soon
Flowmaster exhaust
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
