thermostat and fan switch
Old Jul 26, 2001 | 02:30 PM
red350Z's Avatar
what temp thermostat and fan switch works best. i have a 160 them. and the switch that on at 176 and of at 166. is this ok. thanks for all the help im new at this computerized car stuff
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
Old Jul 27, 2001 | 12:58 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
There are people running that exact same setup here and are happy with it and there are some that have it and they dont like it because it is too cold in the winter time or during cold mornings. If you just plan on driving it during really hot days that would be just a fine setup. When I have the time I am going to follow the tech article on this page that sounds like it will work the best for all around driving.
Old Jul 27, 2001 | 08:51 AM
IROCKER's Avatar
It all depends on the weather where you live. In a hotter climate, further south, that's probably a good setup. I live in Ontario Canada and our summer days range from 10 degrees C to 33 degrees C. This morning's low was 13C and two days ago it was 22C. With varying temperatures like this, the ideal setup is a 180* stat and a 195* fan switch. Anything less and you'll be running way too rich on those cooler morning and killing what little fuel economy we already have!
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
3rd Place Stock Class at annual 2001 JCO Bash
Web: http://www.angelfire.com/on3/whitelightening
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
