.52 Volts ok?
Old Jul 26, 2001 | 10:07 PM
breathment's Avatar
.52 Volts ok?
Hey guys, checked the VOLTS for my TPS, is .52 volts ok?
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 26, 2001 | 11:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
At idle yes, at WOT, no
Old Jul 27, 2001 | 09:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
At Idle (for a stock engine) the voltage should be .54VDC and for WOT is Should Be Over 4.0VDC
Old Jul 27, 2001 | 09:49 PM
breathment's Avatar
will .02 Volts matter any? being that mine is .54?
Old Jul 27, 2001 | 09:52 PM
james_fearn's Avatar
it shouldn't affect anything.
James
Old Jul 27, 2001 | 10:06 PM
Vader's Avatar
The acceptable range (factory specification) is from 0.48 - 0.60 VDC. The presumed "ideal" setting would be the middle of this range, or 0.54VDC. Unless you are using a freshly calibrated Fluke or Beckmann DMM (or an oscilloscope) to check the voltage, the variation is probably far less than the error factor of the instrument you are using.
.52 is just fine.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
