TPI vs.LT1
Old Jul 28, 2001 | 12:12 AM
rockind78's Avatar
TPI vs.LT1
I was just curious on this issue. I already know that LT1 runs a reverse flow water pump and the induction is different. I also know that TPI was used on basic pushrod engines What I want to know is: What are the internal differences between an LT1 and a TPI? Are there any? Also, can LT1 induction be used on any post-86 block or are there only certain ones? The reason I am asking I guess is because I found a wrecked cop car out in the junk yard with a complete LT1. It was at a pretty good price and it certainly got me wondering. Thanks guys!
Old Jul 28, 2001 | 02:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The LT1 intake and heads only work on the LT1 block. You could have them modified but its not worth the cost.
If you can get the whole engine for a cheap price, go for it. Keep in mind the Caprice LT1 has iron heads, the Camaro/Firebird/Corvette LT1 has aluminum heads.
Internally there isnt much difference. They can use the same cam, the same lifters, the same pushrods, the same rockers, the same pistons, the same rods, the same crank, etc. Its just the bolt pattern, distributor, and water flow of the intake and heads that is different.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 28, 2001 | 06:59 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Were the Caprice LT1 4.3l?
Old Jul 28, 2001 | 11:32 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Check this site out on The LT1. It Will Help Find Out If It's A "baby LT1 (265CID)" or The Real deal LT1 (350CID).
http://members.fbody.com/96legacy/misc/autorebuild.htm
Old Jul 28, 2001 | 09:17 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
cams are different depening on the year the dowel pin needs to locate the #1 firing posistion engine is totally different the way to tell if it is a 350 is what exhaust 350 lt1 type motor only came with dual exhaust
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
14.53@96mph w/2.33 60'(no traction stick et)
slp catback is finally on!!!
fastchip prom is in.
kicks you in the A.S.S at wot.
FLOWMASTER S.U.C.K.S
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
