FPR cap installation.... in what order do the pieces go?
Old Jul 28, 2001 | 04:43 PM
MrJ's Avatar
MrJ
there are 3. The cap, a black ring with holes in it for the screws, and then the inner FPR assemble with the orange gasket and spring/diaphragm. I just tried installing mine, I put the ring under the cap, then the spring/diaphragm inside, and screwed it down. Fuel leaked EVERYWHERE. This definately isn't how it's supposed to go. Does the ring go in last, after the spring/diaphragm? Or does it go on top of the cap, on the outside? thank you
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old Jul 28, 2001 | 04:54 PM
Vader's Avatar
The gasket/diaphragm assembles against the base, then the stamped spring can/cap, then the round reinforcement ring. The ring distributed the screw pressure across the entire spring can to minimize distortion and leakage.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 28, 2001 | 09:32 PM
james_fearn's Avatar
On some aftermarket AFPR like the one I have, the AFPR is too big to reinstall the load spreading reinforcement piece.
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
1992 Trans Am
May 10, 2023 07:19 PM
gixxer92
Sep 1, 2015 04:32 PM
wayshegoes
Aug 17, 2015 12:00 PM
BBSDesigns
Aug 11, 2015 07:39 PM
