305 tpi v. 350 tpi
Old Feb 15, 2008 | 04:41 PM
camarofool's Avatar
305 tpi v. 350 tpi
I'm sure this has been answered before, but I didn't see it in the stickies. Will a 350 tpi hook up to a wiring harness from a 305 tpi and run, provided you pull the chip out of the ecm and swap in a 350 one?
Old Feb 15, 2008 | 04:55 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: 305 tpi v. 350 tpi
yes, pretty sure the only difference is the 350 setup has 22lb injectors and the 305 has 19lb
Old Feb 15, 2008 | 05:04 PM
IROCc_916's Avatar
Car: 86' I ROC
Axle/Gears: 373 rear disc
really? but if you have a 305 and change it to 22# injectors you dont have to change the ecm. usually just the regulator. how does changing it to a 350 make you have to change it?
Old Feb 15, 2008 | 05:15 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
hmmm....I thought the regulators were the same. And maybe the MAF setup could adjust to the injectors, but I wouldn't think a SD setup could.....
I'm just learning myself, so if anyone could shed some light on this, please do.
Old Feb 15, 2008 | 05:27 PM
IROCc_916's Avatar
Car: 86' I ROC
well thats exactly it.. the MAF (manifold air flow) would probably work because the ecm would adjust a-f-r and retard or advance timing. but the MAP(manifold absolute pressure) sensor just reads absolute pressure so thats why im thinking it would work.. theres not that big of a change in injectors so im thinking it would be fine.. but he should find someone who already did it.
Old Feb 15, 2008 | 06:15 PM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
The knock sensor is different on a 350 as well. I think the ESC was different as well on the older TPI's. Not much changed though.
bamaboy0323
Sep 3, 2015 06:07 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
