WHAT'S A NINTH INJECTOR GOOD FOR ANYWAY?!
Old Aug 1, 2001 | 05:38 PM
SHOGHALL's Avatar
I JUST GOT THIS 1986 TPI SETUP AND IT HAS A 9TH INJECTOR -- WHAT THE HELL IS A 9TH INJECTOR?! DO I NEED THE THING, IT SEEMS LIKE ITS MORE TROUBLE THAN ITS WORTH.
ALSO, CAN I USE A 1987 AND UP DISTRIBUTOR WITH AN EXTERNALLY MOUNTED COIL WITH THE 1986 TPI SYSTEM OR ARE THEY THE SAME ANY WAY (I'M NOT SURE, MY UNIT IS IN PIECES)?
Old Aug 1, 2001 | 05:45 PM
R.O.B.'s Avatar
In the earlier systems, the 9th injector is the cold start injector. Later, they just added extra fuel to the chip during cold starts, and eliminated the extra injector. You can buy pass it though.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
twest2k2
Aug 24, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
