help ! Idle at 7000 rpm
I need to know to set mt rpm's back to 5000 or lower. I just had motor rebuilt , boared stroked and camed . i know it is timed 8% at 5000 rpm . I just cant see the rpm's being 7000 in gear at a light . It never gose down , enen in park it stays at 7000 in gear sometimes it will drop to 5000 .
Thanx if you can help !
Car: 04 GTO
Transmission: M12 T56
First off i think you mean 700, not 7000. If you were idling at 7k you would have pistons on the ground, through your hood, con rods in the tires, etc. It'd be a mess, lol.
With that said, you idle speed is controlled by the ECM. Unless you have your minimum air set way high or way low, it will always idle where the computer wants it too. The ONLY way to change this is with a chip.
Car: Damn
Engine: This
Transmission: New Stuff
7000?
That's one mean idle!
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
