Fuel Pump Going?
Old 02-18-2008, 03:45 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Fuel Pump Going?
I have a whinning noise coming from the rear , below the seats. The noise has been there for about a year but basically I ignored it, I suspect it's the fuel pump. I notice the noise is more proniunced when the tank is 1/4 or below, is this normal or should I expect to replace the pump soon?. The car seems to run ok, could it just be a dirty fuel filter that is causing the pump to be strained and make the whinning noise?. Any suggestions are welcomed.
Old 02-19-2008, 08:22 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: Fuel Pump Going?
I have the same thing happening. Someone told me that it is common in GMs because of somevibration from the pump to the bottom of the tank... I am not completely sure though... If anyone knows anything about this I would also be interested in more information.
Old 02-23-2008, 04:56 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i have a whining noise to ..
but mine only whines when the car is under load .. sounds like a wheel bearing or something ..
but the fuel pump is an idea ... havent thought about that
Old 02-23-2008, 07:16 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Update,
I stopped by my local shop the other day, I asked my guy to take a listen-to my dismay,he confirmed it was the fuel pump. Just to double check, he took off the gas cap and I could hear it howling. He suggested I try a new fuel filter first before I go for the fuel pump.
I asked if this was usual for 3rg Gen's to have a howling fuel pump, he mentioned he heard it could be common.
My questions is, has anyone else experienced a howling fuel pump and still be able to operate it without problems, is this normal or should I be safe and replace it. let me know.
Old 02-23-2008, 07:36 PM
Transmission: 5 spd
ill check tommorow if mine makes noise ..
what did u do, just take off the cap and you can hear a weird noise? ..
i have a whining noise while going down the road .. but i only get it when the motor is under load ..
do you get the same thing, or is it all the time?
Old 02-23-2008, 07:38 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Plugged or inop fuel tank vent valve or canister purge valve can also cause vacuum and/or pressure to develop and contribute to increased noise.
Old 02-24-2008, 11:26 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
I would notice the howling both ways, either driving or at idle.As I mentioned earlier, it is usually when my tank is 1/4 or below and when i removed the cap it was more pronounced. My car is garaged for winter and happened to take it out last weekend for a spin, unfortunately NY got dumped with 6 inches of snow the other day therefore I have not taken for a ride this weekend.
I will have my car checked out in a few weeks to get ready for the spring cruising, I will have my guy check the fuel pressure, I guess that will be a good starting point to check if my pump is shot.Hope this helps...
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
Glowsock
08-02-2020 07:36 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Fuel Pump Going?
