few questions.
Old Feb 18, 2008 | 05:47 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
few questions.
currently runing a 5.7 l98 tpi .. i need to reset my timing.. yet i have a msd 6al box with the harness for the gm coil and a adjustable Timing Control pn 8680..do i have to disconnect my msd and run the stock set up.. disconnect the tan with black wire from the computer . adjust my timing. connect the wire back .. then hook up the msd set up ??
Old Feb 18, 2008 | 10:19 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: few questions.
Might be easier that way..... or, set the timing control to whatever passes for zero (not affecting timing in either direction) and see what happens. The multiple spark at idle speeds may, or may not, give your timing lite fits....
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
apie2546
Sep 20, 2015 01:03 PM
