plenum need boring when using a 58mm TB
Old Feb 19, 2008 | 10:52 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Just curious if the plenum holes need to be enlarged to bolt a 58mm throttle body in place of a stock unit.
Old Feb 19, 2008 | 11:14 AM
Guest
Guest
Posts: n/a
Re: plenum need boring when using a 58mm TB
I dont think its absolutely necessary but it would be pointless (and likely detrimental) otherwise.
Old Feb 19, 2008 | 11:16 AM
Engine: 4.0 V-6
I'm just asking cause my throttle body bushing are really bad and got a good deal on this 58mm. So wanted to know if it is a direct bolt on.
Old Feb 19, 2008 | 11:18 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Yes, the plenum air-inlet holes will need to be enlarged to match the size of the throttle bores in the 58mm t/b, maybe to clear the throttle blades as the lower half of the blade swings through the plenum opening. I had to enlarge them to fit a 52mm t/b. Otherwise, the 58mm would 'bolt-on' to a non-modified plenum.
Bill
Old Feb 19, 2008 | 11:33 AM
Engine: 4.0 V-6
Linson
Oct 24, 2025 02:00 PM
toronto formula
19
Oct 6, 2015 12:27 PM
hartsmike
Oct 2, 2015 07:11 AM
