TPI Vacum leak.
Old Jul 31, 2001 | 06:55 PM
bombero437's Avatar
TPI Vacum leak.
I replaced the EGR valve on my 89 305 TPI 5-speed IROC. I replaced all the gaskets to mthe intake with GM gaskets, rebuilt the TB, and replaced th O-rings on the injectors. Put it all back together and now the RPMz are veru\y high and I can hear vacum comming from somewhere around the runners or the plenum. was I supposed to use a sealant, or is there a set torque for the boltz that I did not do?
Old Aug 1, 2001 | 01:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Take the runners and plenum apart and make sure you didnt bend a gasket. Also make sure you tightened all the bolts. They dont need much, just snug fit, like 20-25 ft/lbs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 1, 2001 | 08:56 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Check the large fitting on the back and almost below, (drivers side) and make sure you didn't miss that line. Drove me nuts for about 20 minutes last time I has mine off.
_ ___ _
SMasterson
Old Aug 2, 2001 | 06:42 PM
bombero437's Avatar
Ok, I took everything off and reinstalled it again, But I still have the vacum leak. The gasket kit I got from GM came with Blue RTV Gasket Maker Sealant. I did not think I would need it. Do you guyz think I should use it with these gaskets? It sounds like there is a leak at the plenum or the runners, and it is sucking inward very hard!. all vacum lines are good, I cant think of anytrhing else it can be
mike_c
Aug 27, 2015 04:32 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
theurge
Aug 21, 2015 12:46 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
