SLP or anyone with header knowledge
Old Aug 3, 2001 | 12:31 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i guess this question could apply to anyone with headers and air conditioning. i have an 86 IROC w/ a/c on the driver side. has anyone gotten headers to fit without modifying the a/c bracket? Could i survive without this bracket. The bracket goes right over the manifold. I just called home and my headers have arrived with the install kit and cat adapter but I bought the kit that doesn't come with the bracket. He said the $110 kit was for A.I.R. and I didn't order a.i.r. What should I do?
Old Aug 3, 2001 | 07:08 AM
Kyle F's Avatar
A.I.R ins not Air conditioning, its you emissions stuff. It should bolt up and you A/C should not be bothered. YOu will have to rmove you air pump and all those silly little tubes coming out of the maifolds.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Aug 3, 2001 | 08:55 AM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i don't have the air pump on the car nor the reservoir tubes coming from the manifolds. Just looking at the bracket over the driver side manifold appears to only be a 3" gap... if that. Should I just try to lower the primary under the bracket and up to the head without removing the a/c assembly.
Old Aug 3, 2001 | 10:56 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well this must be the v-belt setup since it is an 86 (my 87 is also a v-belt setup). I no longer have the A/C on my car but as I recall, there was a tubular metal bracket that extended from the A/C compressor back towards the firewall at a downward 45* or so angle and had one of the manifold/header bolts go through it. My car had the Edelbrock TES on it when I bought it and the A/C was still installed. I seem to remember that there was a spacer between the bracket and the header flange that made up for the difference in the thickness of the old manifold versus the header flange. Is that what you are talking about? I no longer have to deal with this stuff since I removed the A/C system when I did my engine build (it was already empty and the compressor was shot so.....). If that is the bracket you are talking about, I think it wouldn't be all that bad if you ran without it. Brackets like that are there to provide stability to the belt system to lengthen bearing life for the pulleys and preserve the belts themselves. You really should not have a problem getting it to work though. The install kit should have spacers and washers to accomodate all of your accesories if it is designed for your exact application (v-belt setup, not serpentine). I do not have experience with the SLP headers myself so maybe someone else can shed some light on this as well.
Good luck.........
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB, '99 Camaro seats.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard.
Old Aug 3, 2001 | 04:35 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i had the same problem you did you have two options mark the bracket so a bigger circle can be cut or call slp and get the bracket that's what i did.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,new springs,aluminum driveshaft.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
anyonne from new jersey interested??????
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
alpine247
Sep 16, 2015 05:25 PM
89fast5oh
Sep 8, 2015 09:55 AM
