tpi converted to lt1..
Old Feb 20, 2008 | 08:40 PM
litlbabiboi's Avatar
Hey guys I am thinking about taking my 1987 iroc camaro and taking the tpi off and puting on a lt1 set up..What all do I have to do and how much do you think it would cost and how hard do you think it would be...
Old Feb 20, 2008 | 09:30 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: tpi converted to lt1..
First thing's first, take it easy with the big font and the color. There is no need for it. Next try searching, this has been explained so many times that it is hopeless to post this because no one will answer. Good luck and trying searching.
Old Feb 20, 2008 | 09:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
its not that hard to convert the manifold and the heads, just takes some skills and tools.
does take some time depending on your tools and skills using them
search for this cuz it has been covered
Old Feb 20, 2008 | 10:23 PM
all4u's Avatar
Car: Firechicken
Old Feb 20, 2008 | 10:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i've done the LT1 intake conversion and the biggest thing is getting a distributor spacer at the right angle and making a hold down bolt hole. Its preffered that you weld up extra material on the manifold too but i used JB weld and epoxy steel putty
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Sanjay
Aug 12, 2015 03:41 PM
Thirim
Aug 9, 2015 06:19 PM
