Please explain some parts of the TPI setup
Old Aug 4, 2001 | 12:57 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just received my TPI system from a 91 Transam to put on my new engine...I have a few questions. First, I recieved the tpi setup, computer, wiring harness, most of the sensors.....I was looking at the harness...and most of the stuff is labeled..but there are a couple of wires just hanging out not doing anything...the one that stood out the most was a white wiring with all the wires of the starter and I think temperature sensor (label said knock sensor...but the knock sensor is on the other side isnt it??) And the end is bare...like it was cut..any ideas what its for? Second...what is the big black hollow box looking thing with what looks like grease inside...but i actually think it may be padding of some sort...i THINK its the connector to the ALDL......does some of the engine wiring harness go over to the drivers side (besides the relays). Next....what does the EGR valve plug into? I saw the nipple on it for a hose to connect to it..but what hose...and where to...and last...at the front passenger side of the intake manifold (next to the coolant neck) there is a big screw screwed into the manifold with a clamp looking thing....what is this for? Thanks
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Old Aug 4, 2001 | 03:13 PM
camaroguy99's Avatar
<font face="Verdana, Arial" size="2">the one that stood out the most was a white wiring with all the wires of the starter and I think temperature sensor (label said knock sensor...but the knock sensor is on the other side isnt it??)</font>
That is the knock sensor, it's on the pass. side right above the starter.
<font face="Verdana, Arial" size="2">Second...what is the big black hollow box looking thing with what looks like grease inside...but i actually think it may be padding of some sort...i THINK its the connector to the ALDL......does some of the engine wiring harness go over to the drivers side (besides the relays).</font>
that is the firewall connector. It goes into the firewall and has things the ALDL stuff fuse box wires and ignition, along with other stuff.
<font face="Verdana, Arial" size="2">Next....what does the EGR valve plug into? I saw the nipple on it for a hose to connect to it..but what hose...and where to...</font>
that goes to one of the vacum ports on the pass. side of the plenum via a solinoid that has 2 vacum fittings on it, it should be around the coil wires sice they are mounted together.
<font face="Verdana, Arial" size="2">and last...at the front passenger side of the intake manifold (next to the coolant neck) there is a big screw screwed into the manifold with a clamp looking thing....what is this for? Thanks
</font>
couldn't tell you, might be for the wiring harness that goes down to the starter. keep that bolt in there as I think it goes into a collen passage.
There is a great article about alot of this stuff in the tech section. Read the TBI- SD TPI swap. Although the swap thing doesn't apply it tells you how to assemble the TPI intake system.
Hope this helps. good luck.
Jim
Old Aug 4, 2001 | 05:30 PM
Synergy's Avatar
The bolt looking thing might be the nipple for your heater hose. Dunno exactly. Try to describe with more detail please.
Old Aug 4, 2001 | 07:10 PM
mult68's Avatar
Engine: 305 TBI
I tried taking some pictures...but all I have is a crappy Quickcam...and they came out horribly....but close to the water neck, and RIGHT in front of the front passenger side injectors...after the first two passenger front side manifold bolt holes(the ones that screw into the heads)...there is a bolt that is screwed into the manifold...with a peice of metal between the bolt and the manifold...and the metal is folded in a such a way that it looks like it was used to hold a hose or something (folded like a clamp...in a loop) Now I looked at the underside of the manifold...and it kinda looks that it may have just been drilled in there (not from the factory) is there something there...or was it something the previous owner did?
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Old Aug 4, 2001 | 07:22 PM
mult68's Avatar
Engine: 305 TBI
Lets see if these work..if they do...the circles are where the bolt is.
Ok just go to this link http://briefcase.yahoo.com/multiple68 and click on yahoo photo album
[This message has been edited by mult68 (edited August 04, 2001).]
Old Aug 5, 2001 | 07:51 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
That bolt hole is for an alternator brace. Not everyone got a brace there, GM was also using an alternator brace to the exhause manifold too. Either one or the other, I never seen both. I would't worry about it, the metel strap you discribed was probally added by a privous owner.
BTW, the brace to the intake has been discontinued.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
1nastygta
Aug 8, 2015 07:38 PM
