383 almost finished! HP/Torque guess?
Old Aug 1, 2001 | 07:34 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Anyone care to guess, or run this through a Desktop Dyno, and tell me how much HP/Torque I'm going to make?
383 stroker:
638 .030 over, roller motor block, 0 decked
fully balanced by a pro
Scat 3.75 crank
Eagle 5.7 rods
SRP 11:1 pistons (flat tops)-5cc
SLP 51006 Hydraulic roller, Comp cams timing gear and chain installed straight up.
in: .495" 270 218
ex: .502" 276 224
TrickFlow 23 degree aluminum heads w/.039 quench
1.5 Harland Sharp roller rockers
Ported TPI with all of the mods, huge K&N filter through 3" SS pipe through the MAF,
30# SVO injectors, custom chip
373 gears with 295/50/15 rear tires
A 700r4 that's been modified and shifts great
Hooker full length competition headers with 2.5" pipe all the way through dual two chamber Flowmasters
All in a 1989 GMC short bed stepside pickup, 4040 pounds with driver. All third gen. engine and tranny, wiring, etc., just to keep the message board topic correct!
Thanks in advance!
_ ___ _
SMasterson
Old Aug 1, 2001 | 08:17 PM
Yelofvr's Avatar
Boy oh boy, this virtual dyno stuff is fun!! I say 450 ft-lbs and 390-425 HP depending on what you mean by "ported" TPI setup. Your motor is actually VERY close to a motor Lingenfelter has in his small block chevy performance book.
Old Aug 2, 2001 | 12:14 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Looks alot like mine!! And its very fun to drive, just floor it and it smokes ....but know my trans probably gave up.......
OOpps ......time to change sign......
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods, a Canfield headed 383 in the works!! ready May 2001...ok..june...july..and with Accel DFI....looking for SR or miniram....
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Aug 3, 2001 | 05:53 PM
SMasterson's Avatar
Car: '89 GMC Pickup
<font face="Verdana, Arial" size="2">Originally posted by Yelofvr:
I say 450 ft-lbs and 390-425 HP depending on what you mean by "ported" TPI setup. Your motor is actually VERY close to a motor Lingenfelter has in his small block chevy performance book.</font>
At what RPM? What's it look like at 5250 RPM?
I'd like to see that book. Guess I'll look it up later.
Thanks for taking the time and the reply!
_ ___ _
SMasterson
[This message has been edited by SMasterson (edited August 03, 2001).]
Old Aug 3, 2001 | 07:14 PM
IROC5.7TPI's Avatar
My Engine Analyzer program came up with:
344 hp @ 5250RPM
372 Lb. Ft. Torque @ 3000RPM
The stock TPI intake is choking it.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Aug 5, 2001 | 04:26 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
383's are so much fun to put together. I thought I was 'a lucky one' as it seemed nothing was touching/interfering. I went with the eagle kit. Now, #2 rod and #6 are 'rubbing' but still passing over the cam lobe so I had to take them back out and whack 'em on the grinder.
Is there some type of minimum clearence I need. I mean the rod nuts are pretty darn close to the bottoms of the bores only on the even side. I could just slide a piece of posterboard through there so I just touched the edges of the rod nuts on the grinder to add 'a hair more' room. I'd guess about .02" at the least... Is this ok?
Old Aug 5, 2001 | 08:54 PM
86 IROC's Avatar
I'd have to agree that the stock TPI is the culprit. "Ported" or not, it does not have the air flow to support larger cubic inch motors. Now, before I get hate mail - this goes w/o saying. A 383 with a TPI can make respectable HP, but it also will make incedible amounts of low end torque. I'd say that the combination is perfect for a heavy vehicle.
"I know why you want to hate me, cause hate is all the world can seem to see lately....." L.B.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Linson
Sep 21, 2015 01:08 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
