Help! Runner wont come out
Old Aug 4, 2001 | 03:55 PM
genyuschrist's Avatar
Ok, is there some trick. im changing runners and my stock one one the passenger side is stuck . it is hitting the fuell rail and ive messed with it for a couple of hours but it still wont come out. Is there soem easy way to do this??? need help cause my tranny just got back from rebuild yesterday and im ready to drive. thanks
Old Aug 4, 2001 | 04:54 PM
SillyWabbit's Avatar
Car: '91 Formula
If I remember correctly, there's 10 bolts per runner set, or something like that. The more hidden ones are gotten to from the other side of the lower intake manifold and then there's the bolts that are right underneath the fuel rail that you can't really get to that well without taking the valve cover's off. Other than that I dunno.
Old Aug 4, 2001 | 11:36 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
there are bolts that you must loosenn from thhe oppositte sides one by the fuel rergulator the othher on the opposite side then you will haave tto lift tthe fuel rails slightly loosen the 4 10mm bolts securing the rails liftt them out slightly to pull the runner loose
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,new springs,aluminum driveshaft.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
anyonne from new jersey interested??????
Old Aug 5, 2001 | 12:25 AM
james_fearn's Avatar
you half to rotate the top of the runner toward the other side of the car and then remove it. You can't just pull it straight out. Plus I hope you removed all the bolts to it including the one on the right side of the runner that is accessed from the other side of the runner.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
Old Aug 5, 2001 | 02:33 PM
camaroguy99's Avatar
I just removed the valve cover, I guess it would have been a little easier to lift the fuel rail
Old Aug 5, 2001 | 10:38 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I always just loosen the fuel rail bolts a bit and rotate it as mentioned. But if I had spotless like-new runners and plenum, I'd always take an extra 20 minutes and disassemble the fuel rail with a small torx bit, remove it piece by piece, and then take the runners out. You could maybe do it without scratches the normal way, but I don't have the temper for that
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
