Oil Cooler
Old Aug 5, 2001 | 09:20 PM
breathment's Avatar
Oil Cooler
I was reading the FAQ here at thirdgen.com, and it was saying that all L98's got an oil cooler, now is this a seperate oil cooler, or one that is like built in to the radiator, cause i have never seen an oil cooler on my car.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 5, 2001 | 09:35 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The oil cooler is a piece that is between your oil filter and the engine block which coolant is routed through. If you follow all of your coolant lines you'll fine some that lead back there.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Old Aug 6, 2001 | 01:09 PM
chiefz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by breathment:
</font>
scott 88 GTA is correct it should be your heater hose that comes off the raditor.It will come off the rad.
FWIW.If you ever get a motor out of a truck that has an oil cooler do not hook up the line as they were.The trucks have the oil cooler like you where thinking.I know I just did this and ended up pumping oil right in to my raditator. the trucks pumped the oil up to a seperate cooler.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
