Miniram Gas mileage
I'd say on a 350 or 355, that mileage my degrade because you have to run such a looser converter and steeper gears as compared to a TPI set up. But, on a 383 or larger displacement engine - I'd venture to say that it wouldn't be any worse than with a TPI set up. I'll post what I get for mileage when I get my car all done. I have a 383 with a Mini Ram, Accel DFI, a 3500 stall, and 3.73 gears.
"I know why you want to hate me, cause hate is all the world can seem to see lately....." L.B.
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
When I had my LTR set up I was getting 19 mpg or so in town, thats Edelbrock base and runners, SLP cam, and stock heads. When I switched to my current Mini-ram set up (see sig) I now get 15 mpg in town. But I also had a stock converter and 3.23 gears with the LTR set-up.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel 300+ box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.42 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
Glowsock
Sep 11, 2015 11:09 PM
MikkoV
Sep 9, 2015 04:25 PM
