87 intake question
Old Feb 23, 2008 | 11:02 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
87 intake question
ok im a little confused on this...
I have a 1987 trans am with a 305 lg4 carb.
Im going to convert to tpi soon and the system I have is from an 85 tpi car
I know the center bolts on the 85-86 intake are all the same angle and the
87-up intakes have center holes at an angle. I read on here that someone said the 85-86 intakes will bolt up fine to all 305 iron heads w/o modifying the middle holes.
will the 85 tpi intake straight up bolt to the 87 305 cast iron heads or will the center holes need to be elongated on the 85 intake.???
Old Feb 23, 2008 | 11:51 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: 87 intake question
You'll need to oblong the holes on your intake, best to use the beveled washers too,...used be be Mr Gasket carried them.
Old Feb 26, 2008 | 08:57 PM
peanutmrpeanut's Avatar
I have a lower intake that is off of my car that I will give ya but I have already elongated it for the old style heads and it should still work just fine without any leaks atleast it did for me. just pay the shipping on it. e-mail peanutmrpeanut@aol.com
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
