Ok...not hitting closed loop...why?
Old Aug 6, 2001 | 12:06 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
The coolant temp sensor is new and the O2 sensor is faily new...i did the little ALDL thing to see if i was in closed loop...nope..open..now i know where my gas mileage is going..sooooooo why??? lol
I don't have a scan tool or anything...i do have a Stage 2 fastchip but never had a problem with that until now...any advice/opinions would be appreciated
thanks
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 6, 2001 | 12:50 PM
chiefz28's Avatar
did happen to put a low temp thermastat(160*)I've heard that this can be linked to keeping them in open loop.since it keeps it from reaching the correct operating temp for closed loop.
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
Old Aug 6, 2001 | 01:09 PM
fly89gta's Avatar
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by chiefz28:
</font>
yeah but with the stage 2 chip they told me to use a 160 thermo...i just got back i AM running a bit too cool..so i'm gonna wire each fan to a switch so i can run a bit warmer
Old Aug 7, 2001 | 05:29 PM
87_Camaro's Avatar
use a 180 degree therm, its just right
Old Aug 7, 2001 | 07:13 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by fly89gta:
thanks
</font>
So how exactly have you determined that you are not going into closed loop? Did you take the car for a 10-15 minute drive and then test it?
There are so many situations where you can be going into closed loop but by the time you test it as a "snap shot", you can easily be in open loop.
When you first start the engine, it can take 3-5 minutes on its own. But, prolonged idling or long deceleration down a hill can make you go temporarily into open loop.
The best and most reliable way to confirm your car is going into to close loop is with a scan tool connected and doing 10-15 minutes of real world driving. And not "stop n go" traffic either. The scan tool will confirm if you are going into closed loop, how long it is taking and what criteria is causing it to fall into open loop.
If you remained in open loop for an extended time, you should be getting an SES code.
Also, while there is a minimum temp for ECM to go into closed loop, it is a fairly high number (around 40-45*C or 115-125*F). So if the 160* T-stat is functioning properly, it should not prevent you from going into closed loop.
Lastly, if you have an automatic, there is a separate control for locking the TCC based on temperature too. It is a little higher than the control for Closed Loop. So if you can feel your TCC lock, then you can be assured that the ECM is detecting suffient coolant temp to put you into closed loop.
Old Aug 7, 2001 | 10:48 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
As Glenn said, you need to test the vehicle in real world driving. I had a similar situation. My car would never go into closed loop and would set off the SES light on the highway. When I checked to codes, it was the O2 sensor(forgot which code number). After replacing the sensor and checking the contunuity of the wire, the problem still persisted. It ended up being the computer itself. The computer was not reading the 02 sensor and the break in the circuit was within the ECM.
But before you to buy a new ECM, check everything that could make the system not go into closed loop mode.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Pac J
May 17, 2020 10:44 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
80smetalfan
Sep 22, 2015 02:55 PM
