Cold start injector
Old Aug 7, 2001 | 05:32 PM
Bjase's Avatar
Car: 88 IROC
Cold start injector
Someone butchered my '88 IROC before I got it. As near as I can tell, the TPI came from an '87 305. After flushing the coolant, all the temp sensors died. The only one I haven't gotten my mitts on is the one that controls the CSI. Could I just get a chip from an '88 and not use the extra injector?
Old Aug 7, 2001 | 10:24 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
No. As far as I know you would need a chip for a 89. My car is a 89 and it does not have the cold start injector. You would also need the vats turned off on the 89 chip. I think the cut off year is 88 (last year for the cold start injector).
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire hope to get running soon
Flowmaster exhaust
Old Aug 8, 2001 | 04:01 AM
Omar's Avatar
Just out of curiousity, what leads you to believe that the TPI came from an 87 donor car? The only reason I ask is because there is no difference between the 87 and 88 TPI units.
And Aaron is correct.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 8, 2001 | 04:54 PM
Bjase's Avatar
Car: 88 IROC
I was under the (perhaps mistaken) impression that '88 was the year they swapped to the serpentine drive belt, centerbolt valve covers, roller cams, and did away with the CSI. Aside from the CSI, I don't have any of these things. The numbers on the block place it as an '83 305. My VIN calls for a 350. The rear disc setup is gone ( I'm working on replacing the drums), and the wiring was appently hacked together by lower primates. But I still LOVE the car, it just needs alot of TLC.
Old Aug 11, 2001 | 02:35 AM
Omar's Avatar
Ah, I see...the 87 and 88 will both have the same TPI unit, centerbolt heads, roller cam, and cold start injector. But only the 88-up will have the serpentine belt setup.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
[This message has been edited by Omar (edited August 11, 2001).]
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
