fuel filter and IAC questions.. please answer.
Old Aug 11, 2001 | 03:09 PM
kernel's Avatar
i already did all the other tune up stuff and i figure i should replace the IAC valve and the fuel filter too. how hard is it to replace these two things?who makes a good high performance fuel filter? how much should i expect to pay?the IAC i am just going to get a replacement one. it is idling kinda weird right now and i think this stuff should help.
1986 WS6 pontiac trans am
5.0 305 TPI V8
700R4 tranny w/transgo shift kit. borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks,dynomax high flow cat,3"intermediate pipe,40 series flowmaster
w/2 3" tailpipes.
"ponys can run but birds can fly"
Old Aug 11, 2001 | 05:08 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
You will have to pay around 50 to 70 dollars. The IAC will cost you the most and the fuel filter is really cheep.
Old Aug 11, 2001 | 05:25 PM
camaroguy99's Avatar
Yep the fuel filter is just a few bucks but the IAC is pricy. I think I saw it on TPIS' site for like $115. Does the IAc really need to be replaced? try calibrating it and then go out and get a new one if that doesn't work.
Old Aug 11, 2001 | 07:19 PM
kernel's Avatar
see, i dont really know. in the morning when i start it up it will rev up to 1,000 rpms and then drop down like it is going to die and then revs back up. it wont die but it will run kinda rough. i think it is either the fuel filter,IAC,or the TPS. i dont really know what it is.
Old Aug 11, 2001 | 10:49 PM
MikeS's Avatar
The IAC won't cost half that price if you just get a standard replacement from the parts store. I think mine was around forty bucks.
Old Aug 12, 2001 | 01:15 AM
Raul's Avatar
does sounds like a iac problem,
like that one guy said, try resetting the IAC motor...and make sure the air passages aren't clogged from where the pintle of the iac motor rests...
make sure the throttle body is cleaned on the back of the butterflies and the front..
if that doesn't help, then go to a new IAC and see what happens,
i know i replaced mine, and it helped, i bought a misc. type IAC not like a delco type, it was around 50 bucks or so...
if that doesn't work then try a fuel volumn and pressure test.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
perZ
Aug 21, 2015 05:51 PM
