Some help with vacuum lines please?
Old 02-28-2008, 01:55 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
I think my tank pressure control valve might be installed backwards after trying to interpret the autozone vacuum line schematic the best I can. Here's a pic:
I've tried to illustrate how my lines are all hooked up and I hope someone will take the time to look at it and explain what I need to change. Here it is, sorry it's so sloppy.
Thanks guys!
Old 02-28-2008, 02:12 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
Re: Some help with vacuum lines please?
I just found this picture in another thread and It clears up that my control valve should be connected to the top port on my canister, I'm missing the valve/hoses that it shows going from the gas tank line to the bottom port however.
However, I'm more confused about the smaller of the two lines connected to the control valve, where is that vacuum coming from? Also, the autozone schematic doesn't show a valve inline going from the bottom port of the throttle body to the top port of the canister. And in this picture, the valve going to the gas tank line is installed opposite the autozone schematic.
Old 02-29-2008, 11:14 AM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
Anyone who has a car of similar year that hasn't been rigged to hell should be able to answer this just by looking at their own setup, someone please try?
gta892000
08-11-2019 11:16 AM
camarohelp
09-12-2015 05:45 PM
Doobie52
09-11-2015 06:19 PM
IROCtometal
09-09-2015 10:01 AM
snakeshooter
09-07-2015 11:13 AM
Quick Reply: Some help with vacuum lines please?
