l98 engine
Old Mar 1, 2008 | 01:02 PM
wht91z28's Avatar
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
l98 engine
I have 91 z with a tpi 305, I found an 85 l98 vette engine w 66k miles on it. The price is $800.00. I was wondering is that a good price or not. Also how easy of a swap is it to go in my camaro. What would I have to do to my car and what should I keep from the corvette. Thanks guys.
Old Mar 1, 2008 | 01:28 PM
Stephen's Avatar
Car: 87 GTA
Re: l98 engine
88 would be a MAF, so there'd be some wiring differences. The ECM would need to be upgraded to 350 specs (might as well go bigger while your upgrading anyways).
But, for the MOST part, a direct physical swap. Just a few wiring differences to sort out.
Old Mar 1, 2008 | 02:10 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: l98 engine
I think he said a 85 L98, which would be a whole different story no?
Old Mar 1, 2008 | 02:14 PM
Stephen's Avatar
Car: 87 GTA
Re: l98 engine
My bad, but no. 85-88, virtually identical. Except, the cam would be even that much worse...worse heads....Even a worse choice overall.
Old Mar 2, 2008 | 08:27 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: l98 engine
Wiring won't matter, just use the stock 91 setup and switch to a speed density Corvette .bin for the PROM.
Aren't 'Vette heads the same on all the L98 cars. Thought they all got the Aluminum L98s.
Probably have to swap over the accessories from the 91 305 as well..the alt/ps/air/AC
Old Mar 2, 2008 | 09:47 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: l98 engine
Al heads in mid 86 and up. 85 ecm/prom differant than 86-89 maf. those motors were 235 hp or so.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
