Superam or Miniram
Old Aug 14, 2001 | 12:32 PM
Iroc n roll's Avatar
Superam or Miniram
With my mods in the sig below, and some AFR190's in the future. What would be my best bet for an intake? Also what cam would work well with each intake? LT4 HOT cam?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 14, 2001 | 03:45 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
on a 350 go with thhe superram and install the lt4 hot cam 1.5 degrees retarded this will make the cam kick in sooner justt like the ttpi cam annd will run out of steam aroud 6000 right where your superram does.
good luck
Old Aug 15, 2001 | 06:09 PM
CanadianBeast's Avatar
Try doing a search on this topic. There is no end to this argument. I wish someone would make a superminiram then we wouldn't have to argue all the time.
Old Aug 15, 2001 | 09:02 PM
Dan87IROC-Z's Avatar
Well, you really can't go wrong with either intake. But if you are going to use either, you want to use AFR 195s, they'll flow better up high where those intakes really come to life. You made a great choice with the LT4 HOT Cam, its designed for short runner intakes, like what you plan to get! I would advise aganist not installing it advanced or retarded, just straight up will be perfect!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Aug 15, 2001 | 11:10 PM
Thanks for the info. I did the research in the archives. I think the knockout punch was Traxion's rant on how the miniram is the best hands down. He's got me sold on it if I could find it for a descent price. So if anyone would like to defend the superam nows the time. Also, do you know who sells the LT4 cam the cheapest? Is it a GM only item?
Old Aug 15, 2001 | 11:43 PM
chiefz28's Avatar
I'm don't know much about this LT4 cam but here's the part # for the cam I'm running with my miniramm.Which is also the one Traxion reccommended to use with the MiniRam it's a Comp X-treme Energy 08-503-8.It is $240 out of Summit.Just thought I'd throw it at ya since you were sold on Traxion's rant.Something to think about.
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
Old Aug 16, 2001 | 12:03 AM
The LT4 cam is 218/228 I believe and .525/.525 lift. What are the specs on that X-treme energy cam?
gixxer92
Apr 12, 2022 12:09 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BWilcox
Sep 20, 2015 12:19 PM
Mutillator
Sep 17, 2015 04:38 PM
Blown GTA
Jan 21, 2001 11:54 AM
