change idle speed in TPI?
Old Aug 15, 2001 | 08:10 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
I was hoping that the computer from a stock '89 would work in my car. I have a 355 w/ a 276 cam, and headers. The scanner says the desired idle is 675. the car won't stay running at such a low idle. Is there any way to change the idle without burning a new prom?
Old Aug 16, 2001 | 12:15 AM
chiefz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by XaviarRahl:
I was hoping that the computer from a stock '89 would work in my car. I have a 355 w/ a 276 cam, and headers. The scanner says the desired idle is 675. the car won't stay running at such a low idle. Is there any way to change the idle without burning a new prom?</font>
I'm curious as to what scan tool you are using.I'm using a ATUO SCAN X-RAY.And I get that desired idle,and it is always differant never as low as what your getting but bounces around I'd like to know why
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
Old Aug 16, 2001 | 12:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The best way to do it is with the PROM, opening up the minimum air will cause the IAC motor to keep trying to close which isn't very good for its life.
Wade787b
Sep 29, 2015 01:15 PM
ezobens
Aug 19, 2015 10:29 PM
perZ
Aug 15, 2015 01:17 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
