Fuel injector swap in an 88 TPI
Old Mar 5, 2008 | 05:35 PM
Thrill2's Avatar
I have an 1988 I-roc 5.0 TPI (stock exept filters and exhaust)
The car idles irratic and ive checked everything, Last year my bike was doing the same thing until i changed the jets in the carbs and now it runs fine,
Unfortuanality I have to run E85 due to the damn state of MA, and it dident start acting up until E85 came out (corn gas) I was told i have to run double sized injectors like 40lbs, is this right? and if i have to does anyone know where to get the chip reprogrammed mabie a chevy dealer, so it can handle the larger injectors?
Old Mar 14, 2008 | 07:38 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: Fuel injector swap in an 88 TPI
Could be a number of things....Check your TPS make sure it is at .54V....Clean and reset your IAC(Idle Air Control)....Lots of threads on how to do this ..I had that problem a while back cleaned the IAC passage in the throttle body and reset the IAC and that did the trick...Plus I burned a new chip
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Sanjay
Aug 12, 2015 03:41 PM
