Oil perssure dropping and engine knocking
Old Aug 19, 2001 | 04:50 PM
92RSB4C's Avatar
I just got my '92 RS about 3 weeks ago and replaced the front and rear suspension and stripped out the proportioning valve in the process of assembly. Any way, I got that fixed and replaced the 195 thermostat with a 160 and now the knock sensor reading is setting the S.E.S. light. Could this be from lower engine temps or what? I haven't done anything to the engine since I got it(except the thermostat), but it has been losing oil pressure when it gets warm. It is the speed density L98 and has the oil cooler on it. How does that work? And does anyone think it could be the problem to low oil pressure? If anyone can help me, post a message or e-mail me at madaboutmx@aol.com, thanks!
Old Aug 19, 2001 | 06:59 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Get the codes read from your computer as a starting point to see what's going on.
Old Aug 19, 2001 | 10:17 PM
90Form350's Avatar
Well, the oil pressure will drop a little when the engine gets warm because the viscosity goes down as the oil gets hot. The oil cooler doesn't actually run oil anywhere, it just takes cooler coolant from the heater system, and runs it through an adapter thats between the oil filter and block.
1990 Pontiac Formula 350
Rebuilt 355
COMPCAMS 212/212 .440/.440 cam
Flowmasters 80 series.
maroe624
Apr 16, 2017 08:29 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
