Early 305 to 350
Old Aug 17, 2001 | 03:42 PM
Bjase's Avatar
Car: 88 IROC
Early 305 to 350
OK, if I want to put a 350 under my TPI, I can get bigger injectors (or raise the fool pressure), and change to a 350 chip. BUT...the set-up in my car is from an 85-87 (with cold start injector), when no 350 was available from the factory. Is my only alternative to get a custom chip burned?
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Aug 18, 2001 | 08:55 AM
Vader's Avatar
Bjase,
Don't overlook the PROMs for '87 Corvette 350 TPI engines.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 18, 2001 | 04:10 PM
Bjase's Avatar
Car: 88 IROC
I never even thought of Vettes! Thanks.
Old Aug 20, 2001 | 06:33 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Bjase:
</font>
Or you could get an '89 PROM and disconnect the cold start injector.... Of course you'd have to disable VATS on the '89 PROM, but it's possible that you'd have to do that on a Vette PROM also since they had VATS before '89 as well....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Aug 20, 2001 | 02:20 PM
Z28DJP1987's Avatar
Used my stock 1987 305 TPI set up on a 350 crate engine and did the following:
1) 22# injectors
2) 1988 GM chip for a 350 (cold start Inj.)
3) AFPR to lower the 305 FP from 48 to 41PSI
Check my profile.
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam: 450lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors,AFPR&Gage
SLP Intake runners
New GM 1988 chip
K&N filters & Air Foil ,
Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
B-W 9 bolt rear 2:77 Possi. Four wheel disc brakes,245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
Dyno results: 211 RWHP & 282 RWTQ.
264 HP & 352#/ft at flywheel. NEW TOY
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
