How long do ignition coils go for?
Old Aug 21, 2001 | 11:00 AM
Mike89GTA's Avatar
I have 130k on my GTA and I'm trying to find the source of a slight engine knock. Should I replace the ignition coil? I believe it's original..
Old Aug 21, 2001 | 02:17 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I don't see how a coil is causing your knock, look elsewhere.
As for how long they last. Consider they have no moving parts and are basically a lot of loops of wire, theoretically they last forever.
Occasionally after enough heat/cold cycles, vibrations, and maybe some corrosion a wire breaks in one of the loops leaving you with a dead coil.
morrow
Jan 13, 2024 12:29 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
