Issues with cam, need guidance!!!!!
Really need some help guys! I have swapped a 305 to 350 TPI, Replaced knock sensor, EST Control module, TPS, IAC, running hooker shortie headers/ y-pipe And Purchased a 350 prom, running accel 24# lbs Inj. Stock Fuel Pump, Bosch plugs/wires Now the Fun stuff... Had the 350 built w comp cam P/N 08-300-8 hydraulic roller. The motor will idle but sometimes either idle's high or starts to drag and then dies if I dont pump the gas, have played with the ilde screw, would set that properly, but the tach is acting up. The tps is set at .63 and have verified at wide open throttle, have set the timing to 0 The tranny has been rebuilt but waiting to be installed. How can I fix the idle, I talked to a speed shop and they said I need a prom burned exactly to my setup? Also any suggestions with the TACH?
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Axle/Gears: 3.07
Re: Issues with cam, need guidance!!!!!
IAC counts should be in the 20-30 count range at idle in Closed Loop.
Check the MAF wires to make sure none is broker.
TPS voltage should be .54 (+/- .075) mV so anything between .615 and .465 is within the correct voltage range.
Adjusting the Minimum Air Control screw on the throttle body will effect the TPS voltage reading. So after establishing the correct idle RPM by using the screw on the throttle body, you'll need to verify the TPS voltage is still within the correct range. A lot of guys set theirs at .610 mv since it tends to give better throttle response at that setting.
Hope this helps.
Jake
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Jakejr,,, no biggie here but I think its in Volts not mV.
FWIW, I set my TPS to 0.62V at closed idle. And, I have about 20 counts from the IAC at idle.
Also, if there is any surging, look for a vacuum leak.
Hey guys,
Got the tranny in the car, ilde is better after setting at 6 *, The car idles good at startup, but then after warming up starts surging and ilding high, Car is driveable but not able to get the ilde down where it needs to be. Thanks for all your help keep them coming
Street Lethal
Apr 30, 2019 12:14 PM
Fronzizzle
Mar 18, 2019 08:29 PM
