Over tightened knock sensor what could happen?
Old Aug 22, 2001 | 05:32 PM
MATEOZ28's Avatar
I'm having some problems and never knew the knock sensor was supposed to be tightened to 14ftlbs. Its probably around 35-40 right now should I loosen it?
Old Aug 22, 2001 | 07:06 PM
mckenzie's Avatar
hello, i have heard that if you tighten a knock sensor too tight that it won't p/u a spark knock... where as if you leave it too loose, it will show spark knock when its not really doing it. just what i've heard, best of luck, tom
86 iroc 305tpi auto. mild cam
Old Aug 22, 2001 | 07:14 PM
MATEOZ28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MATEOZ28:
I'm having some problems and never knew the knock sensor was supposed to be tightened to 14ftlbs. Its probably around 35-40 right now should I loosen it?</font>
Now that I read it I'm thinking what a dumb question. What I really mean to ask is.... What effect will it have bieng too tight? I'm having some serious performance issues right now and there are no codes.
Old Aug 23, 2001 | 10:52 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There another post w/ the same stuff going on in here right now. The newbie got it backwards, w/ it too tight it will pick up too much engine noise and tend to register false knock. Too loose and it does't pick up anything.
Your loss of performance is very likely b/c that sensor is too tight, at WOT there is a lot of engine noise going on, which is prolly registering as false knock, retarding your timing excessivley.
...ed
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
willyjoejr
Sep 3, 2015 09:26 AM
masonta
Sep 1, 2015 06:40 PM
